Inventor 2017 Adding This Constraint Will Over-Constrain This Sketch Error
cmratzlaff
cmratzlaff
01.jpg02.JPG03.JPG04.JPG05.JPG06.JPGkelly.young has edited your subject line for clarity: Sketch constraints.  Strange behavior?  What am I missing?
leowarren34
Any reason in particular, have you tried auot constrain?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
kelly.young
Autodesk Support
Autodesk Support
Hello @cmratzlaff I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Thanks for inserting the images and attaching the part. It would be a bit easier to follow if you record a screencast showing what you are experiencing but think I got the idea from the pictures, will forward to development to take look.
Please select the Accept Solution button if a post solves your issue or answers your question.
johnsonshiue
Hi Guys,
The behavior does not make sense. It looks like a sketch solver bug to me. The interesting thing is that for the last line segment, instead of using colinear, use two point-line coincident constraints and it will work. I will work with the project team to understand the behavior better.
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
@cmratzlaff After further investigation we have created INVGEN-23588.
Thanks for attaching the file and describing what you are seeing, it was very helpful.
leowarren34
Yay, hopefully patched well before IV2020
Leo Warren
