I Received a 3D .DWG file from another company and was able to convert it into a .IGES file for Inventor 2018 which opened it as a mixture of parts and surfaces. After much work, I was able finally get a usable copy and it needed to be my base for attaching other objects to. Due to the large file size I tried to shrink wrap the original and it rendered in an orange color with yellow edges. I was eventually able to hide the yellow edges by changing the view to shaded or realistic but I cannot change the color of the objects to a galvanized grey. What steps should I take?
Solved by johnsonshiue. Go to Solution.
@Anonymous wrote:
I Received a 3D .DWG file from another company and was able to convert it into a .IGES file for Inventor 2018 ... What steps should I take?
Attach original *.dwg file here (IGES was never needed).
I converted to .IGES as I found it was the only way to convert the mesh into solid parts so that I could eventually create an assembly around it. Attached is the Original .DWG
Hi! I believe you will need to select the Composite node in the shrinkwrap part and assign a color to it. It should work.
Many thanks!
