Surface Unwrap workaround needed
stevec781
Message 1 of 9
stevec781
Is there a workaround to have curves that are projected onto a surface unwrap onto the flattened surface.  I cant see any options to include curves.
All of Inventors competitors can do this so I figure there must be a way to do it.
Replies (8)
Message 2 of 9
kacper.suchomski
Hi
The dialog box offers various options for maintaining the source geometry. Doesn't any of these options solve your problem?
Kacper Suchomski
Message 3 of 9
stevec781
No the selection area only allows for selection of faces, there is no provision to select curves.
Message 4 of 9
kacper.suchomski
What software version are you using?
Kacper Suchomski
Message 5 of 9
stevec781
Message 6 of 9
kacper.suchomski
The entire Behavior section is used to select curves and determine their output.
So, doesn't any of these options solve your problem?
Kacper Suchomski
Message 7 of 9
johnsonshiue
Hi Steve,
I believe there is indeed a workaround. If the curves are on the target surface, you could use Split command and select the curve to split the face. Then use Unwrap command (uncheck "Merge Result Body" option) to flatten the faces. The edges will be retained on the flat surface.
Many thanks!
Software Test Engineer
Message 8 of 9
stevec781
Hi Johnson , Thanks that worked when merge is unselected.
Message 9 of 9
stevec781
No, those options are to control the way the bounding edges unwrap, ie linear forces an edge to remain straight.   You cant select projected curves with those options.
