Surface Unwrap workaround needed
stevec781
stevec781
Is there a workaround to have curves that are projected onto a surface unwrap onto the flattened surface.  I cant see any options to include curves.
All of Inventors competitors can do this so I figure there must be a way to do it.
kacper.suchomski
Hi
The dialog box offers various options for maintaining the source geometry. Doesn't any of these options solve your problem?
Kacper Suchomski
stevec781
No the selection area only allows for selection of faces, there is no provision to select curves.
kacper.suchomski
What software version are you using?
Kacper Suchomski
stevec781
kacper.suchomski
The entire Behavior section is used to select curves and determine their output.
So, doesn't any of these options solve your problem?
Kacper Suchomski
