Surface Tolerance: missing dialogue boxes
I'm trying to give my pin here a surface roughness of 32 um, but I seem to be missing dialogue boxes, compared to others. I've tried giving the model a surface roughness but to no avail, then I tried in the drawing.
What I want is essentially upper and lower limit surface roughness (32-63)
See attached picture. Have I missed something important or is it a bug?
Best regards, Fredrik
Further I will add that I do not seem to have a drop down menu at the top, showing various presets, that others seem to have.
Martin.Tomko
Hi Frederik,
it seems that you have active annotation standard which does not support it. Go to the Styles Editor and active annotation standard, for Surface Texture Symbols,  to ANSI or to  ANSI-mm. Annotation standard can be changed also in the Ribbon>Documents Settings>Annotations.
Martin
AIR_123
Why Have Newer Standards Shifted Focus or Removed Specific References to Ra?
  1. Shift to Functional Surface Requirements:
    • Older standards like ISO 1302:1978 primarily focused on roughness values like Ra because it was a simple way to quantify surface finish.
    • Newer standards have shifted to emphasize the functional requirements of the surface texture. Ra alone doesn't fully describe how a surface performs in terms of friction, lubrication, sealing, or wear. Parameters like Rz (mean peak-to-valley height) and others are more informative for these functions.
  2. Limitations of Ra:
    • Ra is not enough: Ra (arithmetic mean of roughness) doesn't provide detailed information about the texture profile. For example:
      • Two surfaces with the same Ra can feel and function very differently due to differences in peak and valley distribution.
    • Functional concerns: Industries like aerospace, automotive, and medical devices now demand more precise control over surface profiles, which Ra alone cannot deliver.
  3. Standard Consolidation and Simplification:
    • Standards have become more consolidated, encouraging the use of multiple parameters instead of focusing solely on Ra. This avoids confusion and ensures specifications meet diverse engineering requirements.
    • Instead of prescribing a single parameter, newer standards allow designers to choose a combination (e.g., Ra + Rz + Rp) based on the application's needs.
  4. Globalization and Standard Evolution:
    • Standards evolve to meet international needs and modern manufacturing methods (e.g., CNC machining, additive manufacturing).
    • Newer versions align better with global best practices, focusing on comprehensive surface characterization rather than just roughness average.
