Inventor Forum
surface to solid
10 REPLIES 10
Message 1 of 11
1177 Views, 10 Replies
surface to solid
How is the best way to convert a surface file into a solid in Inventor?
10 REPLIES 10
Message 2 of 11
Bud_Schroeder_ADESK
Hello Adolph,
This is the A360 Drive forum, I'm going to move your message to the Inventor forum so that you get help from the right people.
Thanks for posting your question and hope this helps you get to the right location for help.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
Message 3 of 11
JDMather
Stitch or Sculpt.
or
Thicken.
Attach your file here and end all doubt.
Message 4 of 11
in reply to: JDMather
JD,
I am using 2015 Inventor and I don't have the thicken option in the 3D Model /modify box.
Adolph
Message 5 of 11
JDMather
It is there - they hid it in 2015.  Look in the drop downs.
Message 6 of 11
JD,
I request and received a step file of a pump. I received a surface file produced with SolidWorks. When I open the file and expand in the browser I right click on the composite1 and turn off the Translucent option and then try both options Stitch and Sculpt but keep getting errors that the Create stitch failed and Create Sculpt feature failed. I did find the Thicken option under the Modify Panel. I tried that option but did not have any good results. Normally I don't have problems with Step files only with surfaces composites. Any help will be welcomed.
Adolph
Message 7 of 11
JDMather
What version of Inventor are you running?
Message 8 of 11
Professional 2015
Message 9 of 11
JDMather
The file is missing several surfaces - it would take a couple of hours to repair this model.
Can you request a better model from the source?
Message 10 of 11
Will do sir, thanks.
Message 11 of 11
JDMather
Ask them to try to re-import the STEP file and run SolidWorks Import Diagnostics.
The screenshot below is from SolidWorks on their file.
