I have an .ipt that is an iPart. Using the table can I supress workfeatures such as extrusions? I tried to add it to the table but the option to include/exclude that comes up in an .iam didn't come up.
Solved by mcgyvr. Go to Solution.
Can you attach the iPart here?
(indicate which features you want to suppress/unsuppress)
Attached is the file. All the extrusions I need are currently there and on. If you open the table the highlighted column explains more of what I need. Thank you.
Edit the table..
Go to the "Suppression" tab..
Double click the extrusion you want to suppress and then you have 2 options (Compute) or (Suppress)
Edit the table..
I think your iPart is not comfortable.
If you need only one or two additional holes, you could describe them by diameter and two dimensions for their position.
In your existing IPart, you need separate columns for all of your holes.
Walter
Walter Holzwarth
Walter
Walter Holzwarth
