Inventor Forum
Supressing Extrusions
6 REPLIES 6
ASchlaack
481 Views, 6 Replies
ASchlaack
I have an .ipt that is an iPart. Using the table can I supress workfeatures such as extrusions? I tried to add it to the table but the option to include/exclude that comes up in an .iam didn't come up.
Aaron Schlaack
Autodesk Inventor 2018
Dell Windows 8.1 64 bit Intel(R) Xeon(R) @ 3.50GHz 32GB Ram
Aaron Schlaack
6 REPLIES 6
mdavis22569
in reply to: ASchlaack
mdavis22569
can you post a copy of the assembly?
Mike Davis
Mike Davis
JDMather
JDMather
Can you attach the iPart here?
(indicate which features you want to suppress/unsuppress)
ASchlaack
in reply to: JDMather
ASchlaack
Attached is the file. All the extrusions I need are currently there and on. If you open the table the highlighted column explains more of what I need. Thank you.
Aaron Schlaack
Aaron Schlaack
ASchlaack
in reply to: mdavis22569
ASchlaack
Aaron Schlaack
Aaron Schlaack
mcgyvr
mcgyvr
Edit the table..
Go to the "Suppression" tab..
Double click the extrusion you want to suppress and then you have 2 options (Compute) or (Suppress)
Edit the table..
WHolzwarth
WHolzwarth
I think your iPart is not comfortable.
If you need only one or two additional holes, you could describe them by diameter and two dimensions for their position.
In your existing IPart, you need separate columns for all of your holes.
Walter
Walter Holzwarth
Walter
Walter Holzwarth
