suppressed constraints are automatically unsuppressed
- Mute
- Permalink
- Report
Hi All,
I have an assembly (let's call it guide.iam) in which i use positional representations to show the limit positions of a carriage running on a guide. I use suppression in the positional representations, and this normally works fine. So basically:
- position 1: constraint 1 enabled, constraint 2 suppressed
- position 2: constraint 1 suppressed, constraint 2 enabled.
In the master representation i suprpess one of the constraints so they don't conflict. This all works just fine.
But,
I have placed the guide.iam assembly into another assembly, and even if i did not edit or modify guide.iam it sometimes spontaneously yields a mating error. Checking the design doctor then shows there is an issue with the constraint that was suppressed in the master positional representation. If i now open guide.iam to investigate, the constraint is suddenly unsuppressed. Note that i did not modify the assembly, nor did i change any representation, not did i make the guide.iam flexible in the top level assembly or anything. I did not touch it. At all.
How is this happening? Does Inventor unsuppress constraints when updating or something?
Any help would be appriciated here. Thanks.
Misha
