Inventor Forum
Subtracting two objects
10 REPLIES 10
Message 1 of 11
1097 Views, 10 Replies
Hi. I created two solid spheres, one inside of the other. How do i subtract these two spheres from one another so all that will be left is a shell.
10 REPLIES 10
Message 2 of 11
Marco.Takx
With the combine tool you can substract 2 solids from each other
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 3 of 11
JDMather
If the two spheres are concentric - you don't need the second sphere, you could have simply used the Shell command without selecting any faces to remove.
Message 4 of 11
in reply to: Marco.Takx
I have same issue but in a diffrent approch .
this is my first day to ever working/dealing with 3d in any form of way ! so be easy on me.
I am trying to create a foam insert for a case.
I have created the foam dimention which is a box
and I have the model of the equimptment that shuld be place there.
I used your sugestion and it work, well at least one step of it.
the thing is the in order to create the hole that would allow me to phisiclly slide out the model(eqipment)
I need to use the combine method serverl of time and cut and slide a bit out then again cut and slide it a bit out
in order to create the neccesery cut in to depth,
and I get an error when attampting seconed cut
my english is horible sorry but did you understand what I mean ?
I have found a video tutorial for a diffrent softwer to what I need
so you can understand
how ever in this video the model of the eqipment that he use is a simpale cylinder and have a much complex model
https://www.youtube.com/watch?v=6JpK2bEJP-I
can you guys help ?
Message 5 of 11
JDMather
Attach your files here.
Message 6 of 11
in reply to: JDMather
I am not sure how to take the files or were are they located in this softwer wich I am working on 1 day !
its seem as if its all clued based .
can you use this link ?
http://a360.co/1kP4Gaq
the contorller is not my model, I download it from the web.
thanks for reply
Message 7 of 11
JDMather
What program are you using?
Are you using Fusion 360
or
are you using Autodesk Inventor?
I think maybe you are attempting to skip over learning the basics into techniques that you are not yet ready to tackle.
Message 8 of 11
fusion 360
yes I am skipping.
can you tell me please.
is this doable with this software? is this just a matter of learning better ?
Message 9 of 11
JDMather
You have posted in the wrong forum.
The Fusion 360 forum is over here.
Message 10 of 11
WHolzwarth
You can do it. But it's no easy task. And IMO it's a challenge in F360 as well.
2015 files attached once again. First attachment was not ok.
EOP in IPTs needs to be pulled down.
Walter
Walter Holzwarth
Message 11 of 11
in reply to: WHolzwarth
thanks I am really trying my best and I think for one day I hae done allote 🙂
please please tell me then, for this preticilar job
which software would be the most user friendly ?
thanks for all the help so far...
