I have created two frames using the same sketch and two model state items in an Inventor 2022 weldment sub assembly. The model states work as expected and the frame regenerates in both cases. When I added this sub assembly to the top level assembly and link the model states, the frame sketch updates but the frame member do not update accordingly to the sketch. Is the a bug in Inventor 2022 .3 release, am doing something wrong or is there a workaround to overcome is issue? Thank you
Solved by RajSchmidt. Go to Solution.
Hi
Have you tried opening the subassembly and updating?
Kacper Suchomski
I'm afraid that's how it is supposed to work (or rather, not work): https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-7A8F3827-4F52-4D1E-B730-730EEB739097
