Inventor Forum
Sub assembly contains two frame generated using the same sketch but does not work in top level assembly.
4 REPLIES 4
ian_povey65P7M
164 Views, 4 Replies
I have created two frames using the same sketch and two model state items in an Inventor 2022 weldment sub assembly.  The model states work as expected and the frame regenerates in both cases. When I added this sub assembly to the top level assembly and link the model states, the frame sketch updates but the frame member do not update accordingly to the sketch. Is the a bug in Inventor 2022 .3 release, am doing something wrong or is there a workaround to overcome is issue? Thank you
4 REPLIES 4
Hi
Have you tried opening the subassembly and updating?
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
RajSchmidt
in reply to: ian_povey65P7M
I'm afraid that's how it is supposed to work (or rather, not work): https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-7A8F3827-4F52-4D1E-B730-730EEB739097
Classification:UNCLASSIFIED
Thank you for your feedback Raj Schmidt.
