Sub-assembly color not changing in assembly
gregor.leban
Message 1 of 20
gregor.leban
I have this following problem in my assembly:
Using inventor 2020.
Replies (19)
Message 2 of 20
Xun.Zhang
Hello @gregor.leban,
Not sure if there is any appearance override in the assembly or not, try to remove the color override with command Clear in the assembly and hope it helps.
Xun
Message 3 of 20
Sergio.D.Suárez
Hi, try the following.
Select the sub-assembly of your tree (the one that generates the problem) and then right-click "Representation"
Then activate the "associated" box with the "default" configuration.
This should maintain the associativity of colors in your master assembly
I hope this helps solve your problem. Best Regards!!
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 4 of 20
gregor.leban
@Xun.Zhang
@Sergio.D.Suárez
I can't click Associative...
Message 5 of 20
Xun.Zhang
Check the visual style, are you working in the realistic visual style on the top but Shaded in the sub-assembly?
Make sure they are working in the same visual style.
Xun
Message 6 of 20
gregor.leban
I work with shaded Visual Style everywhere.
(It does not change the color to blue if I change to Realistic)
Message 7 of 20
Xun.Zhang
Show me the data and then I can take a look further.
Thanks!
Xun
Message 8 of 20
Sergio.D.Suárez
To be able to label associative you must change the master representation view to default
Mechanical Designer
Message 9 of 20
gregor.leban
The interesting thing here is, if I insert another same assembly it is in the right color:
I don't have a view on the master.
And I can't upload all Assemblies here.
Message 10 of 20
Sergio.D.Suárez
Have you tried to replace the component? You might experience replacing it with another and then with the same component.
Mechanical Designer
Message 11 of 20
gregor.leban
Tried that now, still the same.
Message 12 of 20
Sergio.D.Suárez
If you think you have found a bug, since you can not restore the component to its original state through various means, you could try to redefine each of the restrictions of this component with the new inserted component that does not cause problems.
Anyway, it is difficult to provide help without access to the file in question. You should try to replicate the error in a non-confidential file and try to attach it for analysis. Best Regards!
Mechanical Designer
Message 13 of 20
johnsonshiue
Hi! Please share the files here so forum experts can take a closer look.
Many thanks!
Software Test Engineer
Message 14 of 20
gregor.leban
I'm attaching assembly if it helps.
Message 15 of 20
johnsonshiue
Hi! You only attached the iam files, which contain no geometry. Please attach the ipt files too.
Many thanks!
Message 16 of 20
gregor.leban
Attaching files.
Message 17 of 20
Xun.Zhang
I took a look at the data, it appears that you are reference to a incorrect view representation, please switch to View 1 as below image.
Video: https://autode.sk/2O2arpb
Hope it helps!
Xun
Message 18 of 20
johnsonshiue
Hi Gregor,
Many thanks for the updated attachment! It still has some parts missing but I think I know where the problem is. This is about Design View Rep (DVR). In AF_Sestav_dvojni_LAST ONE.iam, AF_ohisje_1:1 has DVR:View1 linked, but AF_ohisje_2:1 is in DVR:Master. If you want to link it to DVR:View1, right click on AF_ohisje_2:1 -> Representation -> select View1 and check Associative.
The reason why placing a new occurrence of AF_ohisje_2 appears correct is because the default open option (Tools -> App Options -> File -> Open Options -> Assembly -> DVR) is set to Last Active. So, the View1 is always the default DVR on placement.
I am not seeing the cyan color you showed in the image. That color appears wrong. You may want to install 2020.1 and see if it makes a difference.
Many thanks!
Message 19 of 20
gregor.leban
How did I miss that 🙂
Thank you!!
Message 20 of 20
BCrosby
Thanks, Sergio! You just made my life better. I had a large assembly with a few parts that would not stay the color that they should be. Changing the Design View Representation on each of them to default and then clicking associative solved my problem.
Bruce M. Crosby
Broomfield
Engineering Department
GIGABYTE Z490 Vision D (Intel LGA1200/Z490/ATX/3xM.2/Dual Thunderbolt 3/SATA 6Gb/s/USB 3.2 Gen 2/Intel WiFi 6/Direct 12 Phase Digital Power/Intel 2.5G LAN/Motherboard)
Intel Core i7-10700K
Samsung (MZ-V7E1T0BW) 970 EVO SSD 1TB - M.2 NVMePNY Quadro P5000 VCQP5000-PB 16GB
Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 128GB 32GBx4
Dell Ultrasharp U4919DW Curved 32:9 49” Display
Windows 10 Professional 64 Bit
CAT 7 Ethernet
HP Designjet T3500
3D Connexion SpaceMouse Enterprise
3D Connexion CadMouse
Autodesk Vault Basic 2020
Autodesk Inventor Professional 2020
Autodesk AutoCAD Mechanical 2020
