Styles Library Manager in Read-Only
reine_den_andra
Message 1 of 12
reine_den_andra
Hi.
I have upgraded from inventor 2019 to inventor 2023. I have done migration according to all the rules of the art. Now when I want to make some changes in the styles library maganer, everything is in read-only. See picture.
The project is in read-write. I have tested with inventor open and closed.
How do I remove it?
Replies (11)
Message 2 of 12
Alexander_Chernikov
First of all, did you upgrade your Inventor to 2023.1.1 ?
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 3 of 12
reine_den_andra
Just to Build: 208 Release: 2023.1
Message 4 of 12
reine_den_andra
Just to Build: 208, Release: 2023.1
Message 5 of 12
Gabriel_Watson
Are you using Vault? Where do you store your Design Data folder? If these are in Vault you will need to have those checked out.
Message 6 of 12
reine_den_andra
Hi. I am not using Vault. I have Design Data folder on the same server for 10 years.
Message 7 of 12
Gabriel_Watson
You might need to remove read-only in your project file, then switch your Styles setting to Read-Write first:
Message 8 of 12
reine_den_andra
That was the first thing a did. 😁
Message 9 of 12
johnsonshiue
Hi! We have an embarrassing regression in 2023. Some style schema was incorrectly set. Please install 2023.0.1 update, followed by 2023.1 update.
Many thanks!
Software Test Engineer
Message 10 of 12
reine_den_andra
Hi. Ok, I will try that on Monday at work! Thanks!
Message 11 of 12
reine_den_andra
Hi. This solved the problem! Thanks!
I uninstalled the update 2023.1.
Installed update 2023.0.1
Installed update 2023.1
Installed update 2023.1.1
Message 12 of 12
BDCollett
For other finding this, if you installed 2023.1.1 and don't want to revert. Browse to:
C:\Program Files\Autodesk\Inventor 2023\Bin\_NewStylesLibrary\
Edit Weld.xml to
<Weld Version="4" />
