Inventor Forum
Stuck in imperial
5 REPLIES 5
791 Views, 5 Replies
Stuck in imperial
Bare with me i am new to inventor and i am studing at college. I dont know how but i seem to stuck in imperial. Every time i start a new drawing i have to go tools>document settings>units and change to metric. is there anyway i can make this change permanent? Any help would be appreciated.
5 REPLIES 5
I forgot to add i am using Inventor 2010
JDMather
Find the Templates folder and replace the Standard.ipt file with the Standard(mm).ipt file and rename it as Standard.ipt
You will probably want to do this for the assembly, drawing and ipn templates as well.
(in later versions (and maybe 2010) you can Save Copy As Template to replace the standard template.)
BTW - when you installed the software there was an option at that time to set your Standard units.  Later versions made it easier to change after installation.
Cadmanto
Another thing you are going to want to do is if you create your own templates (as you should to secure these settings)
the folder you place them in needs to be pathed inside of your master project file.
The other thing you should look into is change settings inside of the styles editor possibly creating new styles if necessary.
There are videos on youtube that may help you in doing this.
Good luck.
Best Regards,
Scott McFadden
(Colossians 3:23-25)
jletcher
in reply to: JDMather
JD if I read this right he is needing this for drawings not part.
So he will need to set up an IDW template and styles and then save back to templates. and save styles.. This way the default style would be mm.
in reply to: jletcher
Sorry my wording is poor. i was refering to the part. well to be honest i was refering to everything i made a boo boo when i installed the software in would seem. i have now resolved the issue thanks for all your help
