Hi all I attached the part file that I struggle with. Im trying some ways which I found from youtube or Inventor forum but none of them just couldnt solve the problem. I dont know maybe I made something wrong. Can someone help me with that ?
Solved by blandb. Go to Solution.
The original geometry is poor quality.
I would use only as reference in creating high quality geometry from scratch.
What are you attempting to model?
Do you have a picture of something similar from the real world?
āHi sir,
This is the part, I scanned as 3d and menaged to convert to surfaces.
Somebody must have designed that.
Can you contact the source of the Intellectual Property and request a CAD file?
Otherwise - I would remodel from scratch using the scan only as reference.
"The original geometry is poor quality.
I would use only as reference in creating high quality geometry from scratch."
Can you give som hint about that ?
Can you give some hint about that?
I already gave the hint about that in previous image attachment.
How would this surface logically have any Thickness?
You can Thicken most (some? all? I only tried a few) of the other surfaces.
@Mehmet_Fatih_Turker wrote:"The original geometry is poor quality.
The idea is that it serves as a visual template, and you carry out the modeling process manually.
Alternatively, you can draw cross-sectional sketches at certain jumps and then make a Loft.
You can perform another scan with better quality.
Kacper Suchomski
That is another level to do and would take probably sometime to design it. Anyway, I contacted to manufacturer any seems like they sent me anether 3d scanned part but at least better š I tried to convert it to solid body somehow but just couldnt make this either. Probably its better to use cross sectional sketches... Ä°s there any training for surface modeling feature of Inventor ? I mean very serious one. the ones that I found are always for solid models, assy's,analysis but not on surface or how to approach to surfaces.
It is not water tight here:
What is your end goal with this? Is it for reference? If so, can you use this model as is even if it is a surface?
Here is a browser "cleaned" version where it is just the solid.
This design came to me like this. I was trying to apply boundary patch but just couldnt menage to do this. What you have done was perfect by the way but I still couldn't understand that how did you make part from that ? What are those quilts ?
Okay sir I got it, I made one also by following you, thank you for nice solution, I m very apprecciated.
The inside one of that pocket was the tricky one, I just deleted the faces of the partial filling (shown below) and then the last boundary patch worked.
