Structured BOM Total Quantity- Component Level
amarinXG8V6
amarinXG8V6
Hi everyone,
The manufacturer I work for would like to see the lowest "child" level components listed at the true total quantity in the structure bill of material that we use. Unfortunately I can't seem to figure out how to make this happen without some coding and likely a custom iProperty column. I wanted to see if there's another way to get the data to show up correctly before we go down this path of writing some custom code.
The screen shot below describes the essence of the issue. On some projects we build multiple quantities of the same units. I can pattern the components at my top level assembly. This gives me the correct multiplied quantity for the components/ sub-assemblies reporting 1 level down from my top level assembly. The problem is that this multiplier doesn't propagate down to the sub-assembly and children levels of the structured BOM. I have tried to explain how this works with manufacturing but they are adamant that they would like to see total quantities in the BOM down to the component level.
How do I get the top level BOM quantity to multiply down into the lowest level child parts/sub-assemblies so that on the drawings the true total quantity is shown at the part level? I have tried explaining that Inventor natively is showing you how many of something it takes to build (x1) of each sub-assembly but that you have to look at the next level up to determine how many are needed (where the pattern is occurring).
johnsonshiue
Hi! I could be wrong but I think the only way to do that is to enable Parts Only BOM View. But, you will not see the structure.
Many thanks!
Software Test Engineer
amarinXG8V6
Thank you for the response. That's what I realized after this post. I think the best path moving forward is to provide certain print sets as structured and provide the BOM export data in excel as Parts Only. That way the total quantities can be listed in the excel BOM export data but the print shows the structured nature of the sub-assemblies which is ideal for assembly drawings in my opinion as it gives the assemblers as sense of the correlation between the parts and the sub-assemblies.
