Stress Analysis on Hydraulic Press
- Mute
- Permalink
- Report
I need to perform a simulation on the press of an extrusion machine for outsoles. The hydraulic cylinder in the press has a design issue, which causes the bolts on the sides holding the flange to break after a few cycles (mechanical fatigue). It is known that the flange bends when the mold is closed.
For the simulation, how should I apply the 200 bar pressure on the cylinder? On the other hand, how should the contacts between the bolts and the cylinder sleeve be modeled?
The model goes attached.
Thanks for the help.
