Dialog box not showing, Inventor not responding
I had an issue crop up last week that I can't find a solution to. It first appeared when I tried to do a Replace All command. The cursor turns to an arrow and plus sign, but no dialog box appears to make a selection. Inventor is locked up. I can't use Escape to clear the command, I can't do anything to close Inventor. I can right click the icon on the tray but selecting Close Window does not close Inventor, neither does using the "X" in the upper right corner. I have to use Task Manager to kill the task. The Inventor process says Inventor is "Not responding".
I have found that the Open and Save commands will not work, either. I can start a new Iventor file, but when I try to save it, locked up. I have tried to see if the dialog box is off screen, but it doesn't seem to be. I have tried Alt-Tab to see the dialog box, not there. A couple of times, while fussing around trying to get something to work, it suddenly does start working and the dialog box appears. I found I can open a file by double clicking the file in Windows Explorer. Other commands that call a popup box seem to open fine, like Measure.
Work IT folks pushed out updates last week before the problem started, but I have tried opening and saving files from other programs, Excel, Acrobat, Snipping Tool, and they work as expected, so I can't say the Windows calls for dialog boxes are broken.
I checked for Inventor updates. I was running 2023.4.2, updated to 2023.5.2, the latest. I tried the Inventor Reset Utility to no avail.
Something is broken that occasionally decides to fix itself. Not sure where the problems lies. Any suggestions or thoughts appreciated. Thanks.
gordow
Windows 10 Enterprise
Inventor 2023.5.2
