Stress Analysis - new simulation
hello, I am having trouble trying to find the "create new simulation" on stress analysis. I was able to add in the stress analysis, but once I click it, all the options are grey and the "create new simulation" is not there. I'm confused and tried to search the web for a solution, but nothing comes up.
johnsonshiue
Hi! It looks the the Stress Analysis environment was not properly loaded. Try this. Go to Tools -> Add-Ins -> find Stress Analysis -> unload and reload. If it still does not work, go to All Programs -> Autodesk -> Inventor 20xx -> Tools -> Inventor Reset Utility. It will reset all settings back to install default. But, all UI customization will be lost.
Many thanks!
Software Test Engineer
JDMather
Are you running Inventor Professional?
What version of Inventor are you running (including Update number)?
Can you Attach example *.ipt file here?
No, I have Inventor 2021. It's for my class. I have attached an example, below.
JDMather
No?
Students are entitled to Inventor Professional.
I suspect that the answer is really, Yes.
Go to Help>About Inventor
and then using keystroke Shift Win S screen capture the dialog box.
Ctrl v the image here.
