Stop auto rotate view when creating sketch
smilinger
Advisor Advisor
Message 1 of 47
smilinger
When creating a new sketch, Inventor will automatically turn on the visibility of the origin workplanes and rotate the view orientation to this:
This is annoying, I like the workplane visibility to turn on but I don't want it to rotate, is there any way I can stop this?
Replies (46)
Message 41 of 47
Gregor_Jyrna
Is there a fix for the problem now or coming in the near future? Literally cannot start a sketch in a bigger assembly because it zooms out to oblivion. The depth you can zoom back into is also limited in perspective mode.
Message 42 of 47
kacper.suchomski
File -> Options -> Sketch tab
Kacper Suchomski
Message 43 of 47
Gregor_Jyrna
Hey. What do you mean by that exactly?
Message 44 of 47
kacper.suchomski
In the settings you will find the positions for enabling/disabling view rotation during sketching.
Kacper Suchomski
Message 45 of 47
Gregor_Jyrna
Yes. That is not the problem.
Message 46 of 47
AIR_123
Just to remind you Autodesk... Thread is from 2016 🙂 No improvement for such a silly thing in 2025??
Message 47 of 47
johnsonshiue
Hi Gregor,
The only "fix" I am aware of to suppress this auto-rotate behavior on creating a sketch without a visible planar reference is to enable at least one planar reference. Open the ipt and iam template file that you use regularly. Make origin planes visible -> Save.
After that, I believe the view will no longer rotate on creating a new sketch.
Many thanks!
Software Test Engineer
