> http://www.3dcontentcentral.com/parts/browse/Computers/User-Library/88/88/Models/download-part.aspx?id=1639
The forum server software, I guess, is inserting spaces in the link making
it unusable without cleanup.
There is one extraneous part in the sub assy that may be causing your
merge attempt to fail but merging multiple bodies with slightly complex
surfaces can always be a tricky proposition. I would, barring a good
reason not to, simply use it as an assembly. If I had a need to make a
single part from that I would copy necessary exterior surface and fill
in the blanks to enclose a volume (probably omitting some of the finer,
such as fillets, details). A 'shrink wrap' function may give a good
'starter' surface set.
