Standard on a Part
Standard on a Part
Nicht anwendbar
2.914Aufrufe
6Antworten
Nachricht 1 von 7
Standard on a Part
Nicht anwendbar
I want do this standard on this part.
How it can would be?
0 „Gefällt mir“-Angaben
2.915Aufrufe
6Antworten
Antworten (6)
Nachricht 2 von 7
danmachen
Hi there,
Is your question related to how to physically model the knurl profile in the part?
I don't think Inventor has any tool for this so it would need to be modelled in using a revolve cut feature using the standards given dimensions.
What what reason do you need to model this in to the part?
Dan Machen
Ideas that need support:
Circular / Rectangular Point Matrix
Allow Axis & Plane Selection on Rectangular / Circular pattern
Graphical iLogic Programming
Nachricht 3 von 7
JDMather
I would use a Cosmetic Texture Appearance of Knurl, but if you are going to 3D Print this and need a Cut knurl then use a helical Coil cut, Mirror the cut and then Pattern the two.
Nachricht 4 von 7
Nicht anwendbar
@danmachen
almost yes
I want knurling that use DIN 82-rge 0.8 in it..
 @JDMather
How to knurling DIN 82-rge 0.8?
Nachricht 5 von 7
JDMather
@Anonymous wrote:
.. @JDMather
Coil
Mirror
Circular Pattern
Attach your *.ipt file here if you can't figure it out.
Nachricht 6 von 7
Nicht anwendbar
I think almost know what you say but I don't know apply DIN 82-rge 0.8.
Anyway, I attached the *.ipt file.
Nachricht 7 von 7
danmachen
Din 82 RGE 0.8 refers to the 30degree or 45 degree diamond knurl with a 0.8 pitch.
Please see attached model with 30 degree diamond knurl modelled within.
I have set the Diamond size to 2mm x 2mm.
Dan Machen
