Large text
Large text
Large text
I'm doing a model of a 20 inch cube and I'd like to emboss the entire upper surface with text, but I can't figure out how to create text large enough.
I was hoping someone could show me how to create large text in a model that I can use to emboss.
EvanGu
In Format Text dialog, you can input a value in the red field to edit the text size.
Evan Gu
Inventor/Fusion QA Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous did you figure out how to get the text larger for your emboss?
I am checking back to see if @EvanGu response helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Select the Accept as Solution button if a post or posts solves your issue or answers your question.
