Hi there,
Is your question related to how to physically model the knurl profile in the part?
I don't think Inventor has any tool for this so it would need to be modelled in using a revolve cut feature using the standards given dimensions.
What what reason do you need to model this in to the part?
I would use a Cosmetic Texture Appearance of Knurl, but if you are going to 3D Print this and need a Cut knurl then use a helical Coil cut, Mirror the cut and then Pattern the two.
almost yes
I want knurling that use DIN 82-rge 0.8 in it..
How to knurling DIN 82-rge 0.8?
@Anonymous wrote:
.. @JDMather
Coil
Mirror
Circular Pattern
Attach your *.ipt file here if you can't figure it out.
I think almost know what you say but I don't know apply DIN 82-rge 0.8.
Anyway, I attached the *.ipt file.
Din 82 RGE 0.8 refers to the 30degree or 45 degree diamond knurl with a 0.8 pitch.
Please see attached model with 30 degree diamond knurl modelled within.
I have set the Diamond size to 2mm x 2mm.
