Inventor Forum
Square frame
4 REPLIES 4
johan.degreef
190 Views, 4 Replies
Square frame
We need a square frame 400x400 external dimensions. The frame exist of 4 same parts.
in the past, shop always needs to put extra work in the lasered parts to make them fit exactly 400x400
What would be the best way to chamfer the edges?
Inventor 20250, Vault Professional 2025, Autocad Plant 3D 2024
4 REPLIES 4
Hi
Sketch -> Split / Extrude (cut out the outer segments / intersection mode) -> Thicken (intersection mode)
Here is an example with profiles:
https://youtu.be/ygEJkX5xz6I?feature=shared
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
blandb
in reply to: johan.degreef
Make a sketch on the side face and do a sheet metal cut using cut normal option.
Thing is the squeeze of the material at the radius. That looks to be 1/4" plate or so? Maybe more? They might have to grind the squeeze to get it to fit...Software doesn't  show the deformation you show in the pic.
Autodesk Certified Professional
japike
If we absolutely have to have a miter, we'll often form the part long and cut the miter on a saw. if we don't need a miter we'll notch the flanges.
Peace,
Jeff
Inventor 2024
Since the part is bended, shorten the length by 2 thickness and weld the corner.
