Spur Gear Parameter help
Message 1 of 8
I generated spur gear with design accelerator. Now I can't understand the parameters. Means I want to know pitch circle diameter, but in parameter i can see, da_z, da_a etc. Which on is the pitch circle diameter?
And I also want other dimentions list, like module, No. of teeth etc. How can I find them?
Replies (7)
Message 2 of 8
mdavis22569
da_z, is the teeth count...
Look at the table for making the gear ..and look at the Generator and see what matches what value ...
or attach your gears here
Mike Davis
Message 3 of 8
Thanks for your help,
but this didn't work.
I open spur gear generator and tried to match the parameters but i couldn't find the matches. then i generated new gear pair and tried again. Now new generated pair has da_d and da_dw 60 mm. In gear generator dialog box d was pitchcercle diameter with 60 mm value. means da_d and da_dw both are pitch circle diameter.
But I my previious gear pair value of this two are different ! So which value I should take as pitch cirlce, da_d or da_dw?
And Is there any way i can add a table of parameter from part file directly in drawing ?
Message 4 of 8
mdavis22569
Change one and see what happens ...
or post the set that you want values for ...and their values
Mike Davis
Message 5 of 8
I have attached excel file with all parameter list and values,
Message 6 of 8
mdavis22569
da_aw is work Center Distance
da_b is width
da_beta is angle Beta
da_d Pitch is diameter
da_da is Outside Diameter
da_df is Root Diameter
da_dw is work pitch diameter
da_z is number of teeth for Gear1
da_z2 is number of teeth for Gear2
da_lefttooth 1/0 Yes/No Allow is left helix teeth
da_righttooth 1/0 Yes/No Allow is rigth helix teeth
da_straigthtooth 1/0 Yes/No Allow is straigth teeth
Mike Davis
Message 7 of 8
Thanks Can I make a table of this data directly in my drawing?
Message 8 of 8
mdavis22569
I don't believe so ..
I was just showing you what each value means ..
So you could go into your parameters and export them ...and populate whatever you'd like to with it.
lets trying this:
What is the end result you want to see and do?
Mike Davis
