Hello Community,
i try to find out the natural vibrational frequencies of a clutch in modal analysis.
I know the stiffness of the clutch but not the material. So i decide that i define the stiffness of the clutch bei the contact: Spring.
Because i want to find out the rotational frequency, the vertical stiffness has no importance and i define the vertical stiffness as zero.
Now my problem is, that i have the clutch stiffness in Nm/rad and the tangential stiffness in Inventor has the unit N/mm.
Is it importent to convert the Nm/rad in N/mm? And how does it work?
Or does Inventor convert the tangential stiffness alone, when it simulate ja rotational frequency.
Thanks in advance!
Philipp Riemer
