This just happened to me this morning, I split a part into a multibody part and as soon as I did the split, the entire design tree got greyed out. It doesnt matter if I have only one body visible or both of them, the tree stays greyed out. I can still edit features but its annoying to not know what is on and whats off. I opened a new file mocked up a quick part with various features performed a split and same results. Anyone know if this is a feature or an issue?
thanks
Alan
@Anonymous wrote:I opened a new file mocked up a quick part with various features performed a split and same results. Anyone know if this is a feature or an issue?
thanks
Alan
attach the file here
Here is an example. Once I perform the split everything above that is greyed out. I dont think this was the case before.
-Alan
I never paid any attention to this before - but after a bit of experimenting it seems logical that it couldn't be any other way.
I split a simple cube with Split Solid to create two solid bodies from one.
If I expand the two solid bodies I can see the original feature and Solid Body 1 consumed by the operation.
I would not expect to be able to right click and show Solid Body1 or the Extrusion 1 since they are consumed.
If I drag the EOP above the Split I see Solid Body 1 and the Extrusion.
It just means there consumed I believe, just like a sketch turns grey when you perform a extrusion or something.
I have the same issue - and although I can select a grayed out feature and edit, when I try to apply the edit it doesn't accept as is says the face in no longer valid. I did a split then move. I even ttried to delete the split & move to go back to my part before these changes and I still keeps the freatures grayed out and all the "solid bodies" item on the treel list disapears even though I can see the part and the features and everything is grayed out.
Any ideas?
@marco048 wrote:
I have the same issue -...try to apply the edit it doesn't accept as is says the face in no longer valid. ....
Any ideas?
I don't think this is the same issue.
Here is an idea -
attach your *.ipt file here and end all doubt about the "issue".
