SPLIT Feature not working in PDS Ultimate 2018 :-(
Hi Guys,
In PDS 2012 this steps are working properly. Now, in PDS Ultimate 2018 it is not working.
1. Create a new part and Derive any part that has contour shape.
2. Create a new sketch on XZ Plane and Project Geometry ro create a rectangular sketch.
3. Create a Ruled Surface > Normal and select a contoured surface.
4. Now,extrude the Sketch to create a Solid objects.
5. Invoke Split Feature > Trim Solid > then select the Surface as guide. Click OK
NOTHING HAPPENS!!!!
See attach files as reference
WHolzwarth
No problem here, Willie.
Walter Holzwarth
Tom_Sturtevant
Hi Willie,
The problem is reproducible for me.  It seems related to using the Ruled Surface as the split tool.  A work around is to create a zero-offset surface from the ruled surface and use that to do the split.  Make sure to turn off visibility of the ruled surface so it is not selectable during the split.
I’ll make sure a bug gets filed on this.  You should be able to split using the ruled surface directly.
Tom
Tom Sturtevant
Inventor Part Modeling Developer
Autodesk, Inc.
johnsonshiue
Hi Willie,
Like Tom mentioned, this is a bug. There is no reason why Split should fail in this case. Interestingly, Split Part works. The intersection is clear and Ruled Surface is well defined. Another workaround is to use Sculpt command. You can use Sculpt Cut to remove the bottom portion using the Ruled Surface.
Many thanks!
Software Test Engineer
Hi Guys,
Thank you for looking into the matter. Hope that this could be included on the Build Fix as, I am using this method frequently.
johnsonshiue
Hi Willie,
I would suggest you use Sculpt command to cut the body in the meantime.
Many thanks!
