Graphics problem in Inventor 2018
Fouad-l
Hi @Anonymous.
Please go to application options --> Display and change the display quality to Smoother and restart Inventor.
If performance isn't a problem for you, you can also change the graphic setting to Quality (depends on your priorities).
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
LishuangLu
Hi jayarajk,
Thanks for reporting!
This is a known case in Inventor 2018. In 2018 we are trying to improve the zoom performance in drawing view by disable automatic refaceting, which means when zoom in to some scale, the view may not show smoother quality as previous.
If you want to see the smoother shade under the current position, select the view and edit, uncheck Shaded style, then recheck Shaded style, the shade will show smoother as before.
-Lisa
LishuangLu
Hi jayarajk,
In my side, the graphics display issue happens when zoom in the drawing view, but from your attached picture, it looks the problem happens with zoom out, the shaded view with zoom in has no problem, right? Can you provide more information?
My original reply assumes the case happens with zoom in, if yours is different one, we'd better see whether there's anything wrong.
-Lisa
ferrisb
Have you tried cranking up the display quality?
Hi Ferrisb,
Thanks for you guidance I have tried with this setting but problem doesn't solved.
Jayaraj k
LishuangLu
Hi Jayaraj k,
Have you tried what I suggested above? Trying to reedit the Shaded style, then see whether it works.
Meanwhile, would you please provide me whether this relates with Zoom in or Zoom out?
-Lisa
