SPLIT COMPLEX HINGE CLAMP FOR ASSEMBLY & MFG.
m.domina
m.domina
I made this hinge as a part, but need to split it into 2 separate parts so an assembly and part drawings can be made.
Other than make a ton of extrudes, Im not sure how to do it easily
kacper.suchomski
Hi
You can duplicate an element using a zero-distance solid pattern. Then, remove unwanted volume from each solid using the Delete Face command.
Kacper Suchomski
SBix26
Here's the Inventor 2022 format part as @kacper.suchomski recommended:
Note that if you know you want to do this when you start modeling, you can model as two (or many) different solid bodies as you go, instead of trying to split it at the end.
Sam B
Inventor Pro 2027.1 | Windows 11 Home 25H2
ca-d.one
Hi !
I'd try Split, keeping both sides => Make Components.
Quick check on a 40 x 20 x 10 mm test block: Split on a work plane gave 2 bodies of 4000 mm³ each, Make Components wrote 2 part files linked to the master. After changing the master to 15 mm height both parts followed: 6000 + 6000 = 12000 mm³ (picture attached).
Or am I missing something ??
LG
_____________________________________________________________
Ihr fandet einen Beitrag hilfreich? Dann vergebt dafür doch Likes!
Eure Frage wurde erfolgreich gelöst? Dann einfach auf den 'Als Lösung akzeptieren'-Button klicken!
Autodesk Expert Elite Member
Dirk Prante
