Hi
I am a new comer with 3d model with inventor, i try to make spiral stair around big fuel tank, can anyone help me to model stair case with stair case going halfway and landing and continue to the top.
i have attached the model of the tank
i really need your guys help.
Solved by S_May. Go to Solution.
my problem is the going and the rise of the stair tread are not consisitent as you see in the picture looking from top, i have used helical line for guide when i repeat using pattern, but as it goes to the top the run is getting smaller and smaller
many thanks
how did you component pattern that hole? I deleted your pattern and tried again in 2022 and it fails every time. The holes dont stay on the same axis.
@Anonymous
Did you set Direction 1 and verify the Start Point?
Can you Attach your failed attempt here for diagnosis?
Hi! I am not seeing a failure when I recreated @S_May 's model. Make sure the start point and the direction of the rectangular pattern (path) is set correctly. Please share the files here. Forum experts can take a look and check where the problem is.
Many thanks!
