Is there a way to spell check the words in the title block. I know you can spell check words in the drawing area but I am not sure how or if you can spell check the title block entry's.
MJP
Spell check only works in the format text dialog box
Hi! Brian is right. You need to edit the text in the titleblock in order to enable spell check. It does not parse any text object in a file automatically.
Many thanks!
This is the box I use to populate my title box.
There is no way to spell check his box before i enter it into the title block I believe.
Am I using the right way to fill in my title block. I s there a different way that allows spell check.
MJP
That's the prompted entry interface.. Spell check doesn't work in that dialog because its not a true text editing dialog.
Mark Lancaster
& Autodesk Services MarketPlace Provider
MJP
Your attachment isn't working for me but there is no way to spell check prompted title block field data upon entry or prior to saving or whatever..
Inventor only supports spell checking in the normal format text dialog box.. Nothing more.. Nothing less.. Limited to that ONLY..
You have to download the image to your machine and use your image software tool.
Prompted entry is a useful tool outside of using normal iProperties in your titleblock. But as @mcgyvr pointed out, spell check won't work in that dialog or interface.
Mark Lancaster
@Mark.Lancaster No.. Autodesk needs to fix their "#*it 😋 😁
