Can anyone tell me why this is happening? I assume it's in the styles somewhere, but I can't find it.
Similar issue here:
There is a difference in spacing between tapped vs. drilled holes. It uses the same "note" text style...
Different spacing, same attachment point
Solved by SBix26. Go to Solution.
Great minds think alike - I did try with both symbol in and out and it makes no difference. It is a difference between the thread callout and thru hole callout (it's different again on a linear dimension).
That looks just like it should - I'll be getting 2018 in the next week or so, I'll try to remember to report back whether it changes.
