Inventor Forum
Spacing of Feature Control Frames on attachment points (green dot)
5 REPLIES 5
282 Views, 5 Replies
Can anyone tell me why this is happening? I assume it's in the styles somewhere, but I can't find it.
Similar issue here:
https://forums.autodesk.com/t5/inventor-forum/feature-control-frame-attachment-position/m-p/6677352/...
There is a difference in spacing between tapped vs. drilled holes.  It uses the same "note" text style...
Different spacing, same attachment pointDifferent spacing, same attachment point
5 REPLIES 5
SBix26
I suspect the difference between them is the presence of the diameter symbol in the upper one.  This is probably from the AIGDT font; its characters occupy more vertical space than the normal font characters.
Sam B
Inventor Pro 2019.0.1 | Windows 7 SP1
LinkedIn
in reply to: SBix26
Great minds think alike - I did try with both symbol in and out and it makes no difference.  It is a difference between the thread callout and thru hole callout (it's different again on a linear dimension).
SBix26
Here's what I'm seeing on Inventor 2018.  I wonder if there is some difference in dimension styles?
Sam B
LinkedIn
in reply to: SBix26
That looks just like it should - I'll be getting 2018 in the next week or so, I'll try to remember to report back whether it changes.
It is fixed in 2018, so the solution is upgrade for the phantom fixes.
Technology Administrators
