Solidworks (SLDPRT) to Inventor with features - Is it possible?
samsonic3
samsonic3
Is there a way to import Solidworks files (SLDPRT) so that the features are also imported? I wasn't able to do it even with simple designs. How should it be done? The other way around (Inventor to Solidworks) it worked without trouble.
Gabriel_Watson
There is a plugin that could help you in that (Autodesk Inventor Feature Recognition app):
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/How-c...
sundars
Hi @samsonic3
Currently there is no way to import solidworks files with the features. However, we have the capability to import a reference model using AnyCAD workflows. i.e. you can import the file and choose the "reference method" in the import dialog - which means, that anytime you change the SWX file, you can update the Inventor model which references the SWX File and see the updates.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Inve...
You could also find if there is a 3rd party feature recognition program and run that on the imported model to get the features.
-shiva
Shiva Sundaram
Inventor Development
johnsonshiue
Hi! On top of what experts mentioned here, there is a tool called GoToInventor, developed by our partner ITI. It can help translate SWX parts, assemblies, and drawings to Inventor equivalents with associativity.
https://www.iti-global.com/gotoinventor
Many thanks!
Software Test Engineer
samsonic3
I tried to download Feature Recognition but there is no download link in the app.autodesk.com site. It only says
"Download is exclusive to Autodesk Subscription Customers".
I am signed in and have Autodesk Flex so I think I should be qualified to download?
E. Sent an email to autodesk support about the problem.
