Inventor Forum
"Break link" in Shrinkwrap
4 REPLIES 4
r.leonhardt
343 Views, 4 Replies
Is it possible to make "Break Link" in Shrink Wrap default?
For example via registry?
4 REPLIES 4
In 2022 the Simplify tool (which does what Shrinkwrap used to do in earlier versions) remembers your preferences from the last time you ran the tool. You just need to close the application after picking that option and using it once, to make sure your settings are remembered. I could not find in the registry an exact entry for this.
Thanks for the help.
I want to make it the default for all users, so nobody forgets.
It is for publishing assets in the factory design utilities, so we don't drag assemblies in the publishing process.
sundars
in reply to: r.leonhardt
Hi @r.leonhardt
As @Gabriel_Watson mentioned Inventor 2022 does remember the settings, but Inventor 2021 does not. FYI, we have been trying to move away from registry settings to be more independent of the registry, and in 2022 we manage some of these persistent settings differently and the break-line toggle is one of those.
In Inventor 2021, you have to do the setting every time you restart inventor :(. In Inventor 2022, a one time change of the setting will persist.
-shiva
Shiva Sundaram
Inventor Development
r.leonhardt
in reply to: sundars
Thanks good to know 😊
Technology Administrators
