Inventor Forum
solid bodies with different materials in a part
14 REPLIES 14
Message 1 of 15
sivashankarpsg_26
3365 Views, 14 Replies
sivashankarpsg_26
i have created a part with two solid bodies.
I want to give different physical material property to it
But i can only change the appearance
is there any ways to create with different material properties.
14 REPLIES 14
Message 2 of 15
Mark.Lancaster
@sivashankarpsg_26
No only appearance is allowed.
Mark Lancaster
@sivashankarpsg_26
Mark Lancaster
Message 3 of 15
sivashankarpsg_26
is there any other ways for this?
Message 4 of 15
JDMather
Manage>Make Components...
Message 5 of 15
sivashankarpsg_26
yes it may be useful
but i have created a part with two solid bodies and derived it and that was further derived for a need
if i use your solution I  have to recreate everything right!
please advice me in this .
Message 6 of 15
JDMather
Attach your files here.
Message 7 of 15
sivashankarpsg_26
sorry I could not do that
terms and conditions of our company😐
Message 8 of 15
johnsonshiue
Hi! Inventor ipt file can have multiple solid bodies but only one material style. Like JD mentioned here, you can use Make Components command to push each solid body to a part. The assign a different material style. Yes, you will have a source part, two derived parts and an assembly.
Many thanks!
Software Test Engineer
Many thanks!
Message 9 of 15
panzilte
Switch to Solidworks.  Solidwork will allow the user to have  multi body part and assign different materials to each body
Message 10 of 15
soerenstaerk
in reply to: panzilte
soerenstaerk
Yeah, convince your company to do that. Wow
Message 11 of 15
andycathal8088
Observer
Observer
Yes you can! - Make an extrusion (say solid 1). Then make another extrusion only this time, in the extrusion box, hit - Output, and change Boolean to the blue box with the green plus (this should be solid2). This means you have 2 separate solids in one part. Next - on the left, find the extrusion you just created. Right click it - hit Properties - hit Feature Appearance - then pick a new appearance. You now have 2 solids with 2 different appearances in one part.
Message 12 of 15
panzilte
in reply to: andycathal8088
panzilte
You did not understand the original post.  The user has created a part with multiple solid bodies and this user would like to assign different materials to each solid body.  For example a part is modelled with 4 solid bodies.  The creator would like to assign the following materials to each body.
Solid1 - Aluminum
Solid2- Brass
Solid3- Zinc
Solid4- Stainless Steel
With Autodesk Inventor versions R2021 or older one cannot do this in Inventor.  One can only change the appearance as you described.
Solid1 - Aluminum
Solid2- Brass
Solid3- Zinc
Message 13 of 15
johnsonshiue
Hi! Indeed, at the moment, Inventor does not allow a part to have multiple materials (one material property per body). Fusion 360 does have the ability to do that. If that is something you absolutely need, please try it on Fusion.
Many thanks!
Many thanks!
Message 14 of 15
ethan_howardMMXXIV
If I open my ipt with multiple solid bodies in Fusion 360 to change the materials. Can I then open the Fusion changes in Inventor? Will Inventor have this ability in the future so we don't have to jump back and forth?
Off the beaten path - Is there a migration path from Inventor to Fusion 360? We have over a Terabyte of Inventor data in Autodesk Vault. Is this recommended?
Thank you!
Thank you!
Message 15 of 15
johnsonshiue
Hi Ethan,
At the moment, only the model geometry and appearance can be passed between Inventor and Fusion. We are aware of the request to support material style per body but we don't have a good solution. Nor am I aware it is on the near-term radar.
If you want to migrate Inventor files to Fusion, as I mentioned earlier, at the moment only the geometry and appearance in the ipt and iam files will move over. I suggest you try a few files and see if this is a viable solution.
Many thanks!
Hi Ethan,
Many thanks!
