i have created a part with two solid bodies.
I want to give different physical material property to it
But i can only change the appearance
is there any ways to create with different material properties.
Solved by johnsonshiue. Go to Solution.
Solved by sivashankarpsg_26. Go to Solution.
Solved by JDMather. Go to Solution.
Solved by Mark.Lancaster. Go to Solution.
No only appearance is allowed.
Mark Lancaster
& Autodesk Services MarketPlace Provider
Mark Lancaster
is there any other ways for this?
Manage>Make Components...
yes it may be useful
but i have created a part with two solid bodies and derived it and that was further derived for a need
if i use your solution I have to recreate everything right!
please advice me in this .
Attach your files here.
sorry I could not do that
terms and conditions of our company😐
Hi! Inventor ipt file can have multiple solid bodies but only one material style. Like JD mentioned here, you can use Make Components command to push each solid body to a part. The assign a different material style. Yes, you will have a source part, two derived parts and an assembly.
Many thanks!
Many thanks!
Switch to Solidworks. Solidwork will allow the user to have multi body part and assign different materials to each body
You did not understand the original post. The user has created a part with multiple solid bodies and this user would like to assign different materials to each solid body. For example a part is modelled with 4 solid bodies. The creator would like to assign the following materials to each body.
Solid1 - Aluminum
Solid2- Brass
Solid3- Zinc
Solid4- Stainless Steel
With Autodesk Inventor versions R2021 or older one cannot do this in Inventor. One can only change the appearance as you described.
Solid1 - Aluminum
Solid2- Brass
Solid3- Zinc
Hi! Indeed, at the moment, Inventor does not allow a part to have multiple materials (one material property per body). Fusion 360 does have the ability to do that. If that is something you absolutely need, please try it on Fusion.
Many thanks!
Many thanks!
Hi Ethan,
At the moment, only the model geometry and appearance can be passed between Inventor and Fusion. We are aware of the request to support material style per body but we don't have a good solution. Nor am I aware it is on the near-term radar.
If you want to migrate Inventor files to Fusion, as I mentioned earlier, at the moment only the geometry and appearance in the ipt and iam files will move over. I suggest you try a few files and see if this is a viable solution.
Many thanks!
Hi Ethan,
Many thanks!
