Snap to with move command in sketch
jerod74ZCL
jerod74ZCL
Why are Point Snaps and corresponding selection options (Endpoint, Center, Mid of 2) not available with the Move command in Sketch mode?
kacper.suchomski
Hi
It;s possible. Please right-click when you select the base point command to select the snap type.
Kacper Suchomski
jerod74ZCL
Hi Kacper,
Thanks for the response. I found the snap options when selecting the base point on geometry to move. Is there a way to also use snap options when placing it at the new location?
Example: Using move to place a circle at snap>mid of 2, between two points of existing geometry
Jerod
kacper.suchomski
Have you tried it?
Kacper Suchomski
jerod74ZCL
Yes, please see the image for the available commands that pop up from a right-click while trying to place the geometry2025-01-21 08_24_03-Marking Menu.png
kacper.suchomski
In the case of coincidence constraint, you don't need to use the move tool. You can simply grab the element with the cursor and snap it to another point.
But this is just a productivity trick applied to coincidence constraints.
In general, tools for moving, stretching, etc. should be used in an approximate manner, and all relationships should be defined using a constraint set.
Moving objects is used to predefine the position so that ambiguous constraints (possible in the case of complex geometry) do not create unfavorable solutions.
Kacper Suchomski
jerod74ZCL
Got it, applying a vertical and then horizontal constraint to the center point of the circle, and the rectangle worked.
For context: For a two-part pin-and-socket clip, I copied an ellipse for the pin feature on part A and wanted to center it at the midpoint between projected geometry on part B to create the socket feature.
In AutoCAD, after copying the geometry, I would use Move > select geometry > shift+right click Geometric Center for the move point > shift+right click Mid Between 2 Points to place
For Inventor, after copying the geometry, applying a vertical then horizontal constraint seems to achieve the same result, placing the copied geometry between two selected points
The better approach (fewer clicks) I realize now (probably obvious to most), just copy the part file for part A, relabel it, then edit the extrusion for the pin feature to create the socket. Don't know if it would be better still to just make it in one part file ..?
Thanks Kacper for the tip of turning to constraints as opposed to the move command!
