Inventor Forum
Smart Components in Autodesk Inventor. Automatic holes in other parts
1 REPLY 1
valdas_kulikajevasYW7SV
163 Views, 1 Reply
I have a predefined part with holes and I want to drag and drop it to Assembly, so that it would create predefined holes into mated parts automatically.
In Solidworks this is done via "Smart Components" feature. I wonder if similar feature exist in Autodesk Inventor?
1 REPLY 1
Hi! There isn't an exact equivalent workflow in Inventor. The closest workflow is called Copy Objects (adaptive bodies). You may edit the other part in place -> go to Modify tab -> expand it -> Copy Objects -> pick the "tool" part -> set the output as associate surface. Then use Sculpt or Split to create the desirable features.
Many thanks!
Software Test Engineer
