Slow response to new-document and file button.
frank.blom
Message 1 of 8
frank.blom
Inventor responds very slow to the new document and file button.
Its at least 10 seconds, and i cannot click somwhere else.
This started after the upgrade from inventor professional 2022 to 2024.
Anyone who knows how to solve this?
HP Z4 G4 Workstation
Windows 10 pro
CPU: Intel(R) Xeon(R) W-2225 CPU @ 4.10GHz 4.10 GHz
RAM: 32,0 GB (31,7 GB usable)
GPU: NVIDIA Quadro P2200
Replies (7)
Message 2 of 8
kacper.suchomski
Hi
  1. Have you installed all updates?
  2. Clear %temp% folder
Kacper Suchomski
Message 3 of 8
frank.blom
Hi ,
1. I have Build 343, release 2024.3
2. Just cleared the %temp%, doesn't improve the loading times of the marked buttons.
Message 4 of 8
RajSchmidt
Where does your project file look for templates and working directories? Maybe there is a path to some obscure destination which is not available anymore? Inventor will then look for alternatives which might take a while.
Message 5 of 8
frank.blom
It looks for templates on our (cloud)server.
(we changed to a cloud server at the same time we migrated to Inventor 2024)
I have tested the download speed for the template files, and it is 22-30Mbps for the standard.ipt/iam/dwg
A larger step file (270mb) downloading from the cloudserver has an average of 72Mbps
We have a 500Mbps internet, With ookla i measure 470Mbps up and 430Mbps down and 1ms ping
Message 6 of 8
frank.blom
You pointed me in the correct direction!
I fired the old local server up, and did the same download speed test with the standard.dwg from both local and cloud server. Its at least a factor 10 faster with the local server.
I copied and edited the project file so it looks at the old local server, and the buttons work whitin a second.
Switched back to the cloud project file, and its 10 seconds.
So i pinpointed it to server bandwith speed, and confronted my system manager.
Thanks!
Message 7 of 8
RajSchmidt
@frank.blom
Glad to help!
What I would do now is to still keep templates and Design Data in a central place, like your cloud server. But you should implement a routine that automatically distributes these files to each local machine whenever there are changes. Maybe with a Windows login script?
Message 8 of 8
frank.blom
A follow up...
We have now an old work station acting as server for just the design files.
It's an temporary solution.
I want to have the files on a central location, and not an copy on each machine.
The company that supplies our cloud-server is investigating the problem.
They hope to solve it in the near future.
Thanks for your help!
