I am working on a project involving I-beams used as transportation beams, which include a half-ring shell section. Top of transportation beam has four lifting lugs.
I need to lift these beams using the lifting lugs to assess the amount of deformation that occurs. Given this scenario, I would like to know which type of analysis would be most appropriate. Should I perform a stress analysis using the static method, or is there a better alternative?
Give some steps how to analysis the beams.
I appreciate your guidance on this matter.
Best regards
Karthick
