Slow performance opening constraints in inventor 2018.2
Message 1 of 57
I Have all the latest updates using Inventor 2018.2 and I am now having issue opening the constraints button from clicking to opening can take up to 5 seconds before the constraints window opens up.
Any help would be appreciated.
Cheers
Dave
Accepted solutions (3)
Replies (56)
Message 42 of 57
glen_fabatech
Message 43 of 57
eleblanc
That update wes removed and not available anymore, at least for me.
Message 44 of 57
glen_fabatech
Give me your email address I will drop it on the web I think what I got is the complete patch in my downloads
Message 45 of 57
mcgyvr
I'd recommend you just wait for Autodesk to release the update again to avoid any issues..
They removed it for a reason.. Having to wait a few seconds for constraint dialog is something that is not mission critical requiring an instant fix..
Just be patient and Autodesk will have a proper fix out shortly..
Message 46 of 57
glen_fabatech
I guess go crazy then
Message 47 of 57
ChrisMitchell01
2018.2.3 was released today. It should be accessible from your Account or from the Desktop App. If you filter in Accounts then please only filter for updates to "2018"; if you also filter on "Autodesk Inventor" it won't show up.
Chris
Chris Mitchell
PDMS Customer Engagment Team
Autodesk, Inc.
Message 48 of 57
Any issues With 2018.2.3 ? Does it fix constrains issues and New issues after updatng?
Message 49 of 57
blair
Will find out shortly, mind you I didn't run into any issues with the 2018.2.2 patch.
Delta Tau Chi ΔΤΧ
Message 50 of 57
3028.2.2. Was taken down again ....didnt install it
Message 51 of 57
Ment 2018.2.2
Message 52 of 57
Christian_1976
@Anonymous
as @ChrisMitchell01 said, you must search for 2018.2.3
But as he explained the patch is discovered only in specific conditions.
However i found the patch not by sorting with 2018 (it doesn't show to me in that way) but i found it under my All products & services -> product updates
in the first it shows "recommended" (the most unuseful) then i found "Recent" and under it -> Inventor 2018.2.3 Update Severity: High (but not recommended...)
However I really don't understand why it has to be so complicated listing and sorting updates.
In one pc it gived me errors, (like as the patch was already installed in beta, logs said), but i guess was a windows issue, after a reboot and a windows update all worked fine.
Hope it helps
Message 53 of 57
2018.2.3 fixed it !!
The windows for all the problematic commands now pop right on... for now 😉
Thx
Message 54 of 57
I wonder why they don't want to help users of version 2016..... only 2018 update for this 'slowing' problem.
Message 55 of 57
glen_fabatech
That would be like going back and upgrading a 2016 chevy pickup
Message 56 of 57
johnsonshiue
Hi! We are actively working on a solution for 2016. The fix to 2018 and 2017 is much similar. But, the fix to 2016 is not as straight forward. Also, it is not a direct porting. We are trying our best to help. I am sorry for the delay.
Many thanks!
Software Test Engineer
Message 57 of 57
I think that after selling a car they still work on spare parts and support for older cars. If your car brake, you do not buy a new one.
