Hello everybody,
my model tree has gone missing and i cant find it anywhere but in my user interface it's on.
Solved by mcgyvr. Go to Solution.
This is interesting, the check box "Model" should control the visibility of the model browser (model tree). Click it on an off and see what happens. Your browser may be off screen also or on a second monitor.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
They just did that in 2018 and its confused some people already.. It used to say "browser" or "model browser'..
But the Inventor reset utility will also reset it to being shown again and in the correct position I believe if it was off screen.....
Hi! You can also re-enable the model browser by going to the following checkbox.
View panel -> User Interface section -> check Model.
Many thanks!
