Inventor Forum
Slot assembly
4 REPLIES 4
jerome.duverger
336 Views, 4 Replies
Slot assembly
Hi guys,
I can't figure out how to put the cilinder in the slot (two different part in assembly). In the slot it must be able do rotation and 1d translate If i use the planar joint it doesn't allow me to put limits in place (they turn grey and I can't filll anything in). How can I constrain this in assembly?
Thanks in advance,
4 REPLIES 4
Hi!
  • Create a constraint to constrain vertical movement between both parts.
  • Create a mate between the slide axis and slot plane, as in the image below
  • Create a contact set for both parts (Green squares in the image)
  • Activate the contact solver in Inspect tab
CCarreiras
Here you have the files...
CCarreiras
Sometimes using Contact Analysis can slow down the simulation a lot.
You can also consider the option of setting the ranges of parameter changes when applying assembly constraines
See the video.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Thanks both of you.
