Hi guys,
I can't figure out how to put the cilinder in the slot (two different part in assembly). In the slot it must be able do rotation and 1d translate If i use the planar joint it doesn't allow me to put limits in place (they turn grey and I can't filll anything in). How can I constrain this in assembly?
Thanks in advance,
Solved by Alexander_Chernikov. Go to Solution.
Solved by CCarreiras. Go to Solution.
Hi!
Sometimes using Contact Analysis can slow down the simulation a lot.
You can also consider the option of setting the ranges of parameter changes when applying assembly constraines
See the video.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
