Slope Pattern Style Issue
Message 1 of 10
Please see the attached image. Instead of me having to create these separately is there any textures available to get this appearance onto a solid square shape?
James
Replies (9)
Message 2 of 10
Can the image be applied to the part....If yes how do i apply this image to the attached part?
Thanks for any help
This part attached is 2013
James
Message 3 of 10
-niels-
You'll have to make a custom appearance (color) style in order to do this, but yes it is possible.
I'm on 2015, but i think the process is the same in 2013 so i'm going to link you the help page on how to do this:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-BF0A3854-2506-468B-97F7-5A7D5F7905E4
Hope you can figure it out from there.
(you might have to do some internet research on how to create a seamless pattern.)
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 4 of 10
I had a go and got a pattern on the sheet but how do i make it realistic?
How do i make it look 1 piece instead of 4 pieces?
Can the pattern be sized to make it look realistic?
James
Message 5 of 10
-niels-
Can you also post your pattern1.jpg, the texture is linked to it but it isn't automatically included with the .ipt.
As to your sizing question, when you're editing the color you can click on the texture you added and you should get a "texture editor" window.
In that window there are settings for scale that you can play with.
If it distorts the image too much, try making the image a larger pixel size.
Niels van der Veer
The Netherlands
Message 6 of 10
Thank you
I have attached the jpg
James
2013
Message 7 of 10
-niels-
It might be possible to get a seamless pattern from that image, but there's a lot of color variance / shadow.
There is a standard supplied texture called "Fabric2.bmp", maybe that could be a good substitute?
I'll just add the image in case you can't find it.
If it isn't what you want, then search the internet on how to make a seamless pattern and see if you can get one from your image.
Hope you can figure it out.
Niels van der Veer
The Netherlands
Message 8 of 10
Thanks Niels
Thanks for the pattern but i need the image i attached to somehow work...it is not easy getting these patterns to work though
Thanks for all your help
James
Message 9 of 10
-niels-
I gave your texture a shot, it's not perfect but it's reasonably seamless.
(the actual weave pattern is a bit messed up, but you need to look close to spot it.)
Just play with the scale like i mentioned and you should be fine.
Niels van der Veer
The Netherlands
Message 10 of 10
Hi Niels
Very nice.Thank you for help
James
