Skew Fonts
Skew Fonts
vmontefusco
Message 1 of 8
Skew Fonts
vmontefusco
Greetings
Is there a way to skew fonts (words) in Inventor? I know I can use Extrude or Emboss fonts (words) in the +/ Z direction, but I would like to easily change there shape in the X and/or Y direction(s). As an example, let's say I create a word on a part and I'd like to slightly elongate it in the Y direction. Is this possible without creating it in another program (like Fusion 360) and saving it as an IPT?
Vince Montefusco
www imdb com
Replies (7)
Message 2 of 8
SBix26
Probably the easiest method is to edit your embossed/extruded text and change the value of Stretch as shown below:
Sam B
Inventor Pro 2024.1.1 | Windows 10 Home 22H2
Message 3 of 8
pcrawley
If you're extruding/embossing, then you can use Direct Edit to non-uniformly scale in any combination of X and Y:
Peter
Message 4 of 8
vmontefusco
Thank you so much!! Works like a charm!
Vince Montefusco
www imdb com
Message 5 of 8
SBix26
I'm a bit skeptical that @pcrawley 's solution will work for you.  While it does stretch the text, Direct Edit > Scale only works with solid bodies, not features, so it is stretching the entire body containing the text as well.  Is this really what you want?
The technique could be used with text extruded as a new solid, then scaled, then combined (subtracted) from the main body.  But I think the text editing controls would be easier, no?
Sam B
Message 6 of 8
pcrawley
Don't burst my bubble @SBix26 😉   The text extrusion I showed was created as a separate body from the base - so the non-uniform scale only scales the text.  (You're right - I should have been clearer with the explanation/screen shots).  Once scaled it can be combined with the original solid if needed.
(And I took "Works like a charm!" as being a workable solution for the OP 😊)
Peter
Message 7 of 8
vmontefusco
Greetings to all
Thanks for the added information. What I required for my current 3D Printer project text did work like a charm. I will check out the other option mentioned soon.
Thank you!
Vince Montefusco
www imdb com
Message 8 of 8
vmontefusco
Greetings
The answer to your question is "yes". I have been designing 3D Printer products and build the larger parts in sections due to the size of the build plate, then assemble them using a variety of techniques. The part that has the text needed to be skewed and the Direct Edit worked perfectly!
As I mentioned in other posts, I have been using Inventor from almost its inception. I became a certified User via an authorized dealer in LA California and college, however, due to my work load in the entertainment industry, I never went back to update my skills and frankly, I forgot many of the things that could make my life easier designing.
Thanks again!
Vince
